Morso problem!
Badger
Organisation: happy framer
Interests: framing anything!
Morso problem!
Post by Badger »
Hello Framers of the world, long time reader first time poster!
I am looking for a solution to a problem with my bottom knife block, I have about 2mm clearance from the face of the blade and the block itself which is causing unsightly unclean cuts at the base of the frames I cut, but I am unable to/nervous about how I correct this problem, also I need to move the foot pedal about 20mm to the right as its rubbing on the inside of the machine.
Many thanks!
tebbles
Organisation: the frame shop
Interests: music, framing
Re: Morso problem!
Post by tebbles »
At the back of the morso there is a long metal bar with a bolt, you can adjust the height of the blades by twisting the bolt.
Mark Thornton
Re: Morso problem!
Post by Mark Thornton »
Use this to adjust your bottom blades: https://www.lionpic.co.uk/p/9423/Long-T ... Morso--5mm
Mark
Badger
Re: Morso problem!
Post by Badger »
With kind thanks Mark, its greatly appreciated!
