FTAGH- Kity 618 Cast Aluminium Table Saw
fusionframer
Interests: framing
Post by fusionframer »
With the topic about table saw, I realised that I have a kity table saw which needs some tlc, but works. I used to use it as it is, but replaced it with a cast iron machine.
The blade is a 250mm freud blade (I use these on alk my machines), and the only problem is with the raise/drop mechanism so the blade is always at full height.
I have seen that it needs a pin or something simple to get this working and then it will work a treat.
It is an induction motor so is quiet, and the fence does not move (a problem with cheaper machines)
If this would be of use to anyone, you can have it for free.
www.fusionframing.co.uk
StevenG
Re: FTAGH- Kity 618 Cast Aluminium Table Saw
Post by StevenG »
Whilst this would be of no use to me I just thought I would say how decent your offer is :clap: :clap:
Nice play sire :D
Alexis Hemsley
Organisation: Frame 4 Me
Interests: Private flying, golf, carpentry
Post by Alexis Hemsley »
Have sent you a PM
fusionframer
Interests: framing
Now collected.
Alexis Hemsley
Many thanks to Fusionframer for the saw. cost less then £10 to put right, very happy
