This just happened!!!! What do I need to fix this???
I've got a guy doing a charity thing tonight, wanted some framing for the event. I have to call him now with be the good news
Talk about bad timing, you really couldn't make this stuff up
CS88 help!!!
- StevenG
CS88 help!!!
- IMG_20171118_125322.jpg (3.02 MiB) Viewed 4768 times
Re: CS88 help!!!
A turnbuckle and cable clamps for each end. It's an easy DIY project.
https://www.homedepot.com/p/Everbilt-1- ... /204273916
https://www.homedepot.com/p/Everbilt-1- ... /205887928 or https://www.homedepot.com/p/Everbilt-3- ... /205887661
or
new wire cable and 2 cable clamps with eyelets.
or
- Organisation: SGF
- Interests: Music Music Music
Re: CS88 help!!!
I would say you need a new cable. If you were nearer you could have my spare one! Make sure you order two!
- StevenG
Re: CS88 help!!!
Very generous offer yes, I'll order two.
Home depot is slightly far away btw but point taken, not sure if I fancy doing a DIY job, I'd probably mess things up & time isn't something I have a lot of at the moment.
Cheers guys
Cheers guys
- Organisation: thought I was
Re: CS88 help!!!
How about a bicycle brake cable??
Re: CS88 help!!!
I had one of these cables fail on a CS-79 some years ago. When examined it I found that the pulleys were not revolving freely and the friction has caused the weakening of the cable. It's well worth checking this and if necessary relubricating the sleeve bearings with some Molykote GN paste.
- StevenG
Re: CS88 help!!!
Right, two cables ordered. Thanks for the tip Mark, I'll be sure to check the pulleys when the casing is open
