Hi!
Looking for any suggestions...
The cartridge spring in my CS88 snapped the other week. Got a replacement (quicker than I would have thought possible!) from Mark at Underpinner spares and fitted it.
Since I fitted it though, it won't push wedges deep enough in to the moulding. They go in about halfway, even with the pad right up against the wood.
I'm assuming it's not related to the cartridge spring and more to do with my putting it back together. Can't spot anything obviously wrong though...
Any ideas?
Thanks,
andrew
CS88 help!
- Mark Thornton
- Organisation: Underpinner Spares
- Interests: Red wine - lots and lots of it.
Re: CS88 help!
Hi Andrew
You have fitted the screw that retains the cartridge spring into the lower mounting holes when it needs to be mounted in the upper holes.
(Thanks for the comments)
Mark
Underpinner Spares
Mark
Underpinner Spares
Re: CS88 help!
Changing that spring is not an easy thing to do. I've only needed to change one, but I had a lot of trouble getting it to work properly afterwards. I can't remember much about it now, but it nearly drove me mad at the time.
- Mark Thornton
Re: CS88 help!
This picture may help.
Mark
Mark
Re: CS88 help!
Wow.Mark Thornton wrote:Hi Andrew
Mark
Underpinner Spares
I'm not sure who you must have sold your soul to in exchange for your framing knowledge...but it seems to have worked.
Can't say enough good things about you just now!
