Hi can someone please tell me how to clean my Morso BA
It's not that important as it does not hinder the machine, the metal is different colours. Would just like to know if this can be cleaned with and agent that causes no harm to the machine. See picture
Cheers Aaron
Morso cleaning
Re: Morso cleaning
looks clean to me, cast iron goes that colour,
- Ricky
Re: Morso cleaning
I use this, and on my underpinner too, it works on all Metals Fibreglass & ceramics,
Re: Morso cleaning
I never clean mine. It looks a disgrace but it works.
The underpinner is even worse.
Re: Morso cleaning
I don't actually clean my morso, but from time to time I rub a bit of paste wax on the exposed surfaces of the cast iron bed. To be honest, I'm not sure that it matters much, but I like mouldings to slid in place against the measurement stop nicely.
- Organisation: Game of Frames
- Interests: All things zombie. I also do data recovery.
Re: Morso cleaning
When I can feel that the cast iron surface has lost its glossy feel I give it a little squirt of WD40 and a quick rub over with some fine wire wool followed by a buff with a clean cloth. The muck that is removed is surprising and the surface is then back to a nice clean and smooth working surface. It takes about 30 seconds to complete whole process. This helps the moulding slide into position and reduces the ability of small particles to grip to the surface (the ones that are likely to jam into the sliding measure and cause problems there).
- Photal
- Organisation: Photal Photography Gallery and Framers
- Interests: Photography/Art and Design/Carpentry and Joinery/Nature/Rugby/Running/Music and seeing bands/Sci-fi
Re: Morso cleaning
cheers for the advise. I used to use that PEEK stuff for my bike wheels. I will give the WD40 a whirl, its's just so I can see the marking's
Aaron Broadhouse
