Hot Press + Jigsaw
Trinity
Organisation: Trinity Framing
Hot Press + Jigsaw
Post by Trinity »
Does anyone have experience of dry mounting jigsaws in the Hot Press?
What temperature and for how long if not my standard 90 ish and 2 mins 20 secs that I use for posters and the like?
Keith
absolute framing
Organisation: Absolute Framing
Interests: Reading the Lion Catalogue
Re: Hot Press + Jigsaw
Post by absolute framing »
I use Dry Mount Film as opposed to tissue for this.
Peel off one side of release paper and puncture film with roller
Pop in press for 1.20 at 90
Take out and let cool.
Peel off release paper and use this as a carrier to maneuver/slide the jigsaw in place.
Then back in the press at 90 for a few minutes depending on size
Film is stronger than tissue so is better if using a mount.
Good luck
Stephen
Stephen Strahan
absolute framing
Stephen Strahan
I do them the same as absolute. Pre-mount the film and then arrange the puzzle - quick squeeze in the press - done.
If you cut the film just slightly smaller than the puzzle and mount to a suitable colour mountboard you can get a nice
floated look with the edges visible.
Trinity
Post by Trinity »
Thanks gents, it'll be a first then for the piercing roller I've never used yet, have you any advice on the extent to which you roll - much / lots / etc
Trinity
Post by Trinity »
Actually a look in the Hot Press book indicates lots of holes - 10mm c/s b/ways.
I shall give these people a ring later
http://www.mountingsubstrates.co.uk/col ... -film-4000.
I've stacks of stuff for the hot press but of course no film, sods law.
Where I used to work, we only used tissue and never had a problems, even with jigsaws :sweating:
Tissue just as good, but film is a bit easier as it gives you a tacky surface to arrange the puzzle on. :idea: :D
The Common Framer
Organisation: The Horsell Framing Company
Interests: Photography, Boats
Post by The Common Framer »
I have done 5 on the hot press with tissue. also had no problem. 90 degrees and around 5 minutes seemed to work
sisters
Organisation: hereford
Interests: ummmmm picture framing !
Post by sisters »
Always have used tissue, dont put a jigsaw in that has been made using customers photo tho....... they melt! :head: :head: :head:
Trinity
Post by Trinity »
Thanks very much for the helpful hints,I'd decided to go with the tissue as I have it but sisters post brought me up short - this is a jigsaw - looks normal card and paper front, but made from an image supplied to the jigsaw making company, you didn't mean this sort of thing did you when you mentioned melting?
Trinity
Post by Trinity »
In the end I've ordered the Hot Press film from Wessex, with a very understanding customer whose ok to wait until 8 May, the due in date to Wessex.
How on earth could I contemplate continued assistance from Steve Goodall and then go elsewhere for my stuff - it must have been a senior moment.
sisters
Post by sisters »
sorry never got to see your post
Yes image was a photo that had been made into a jigsaw. my guess is with gel ink ....that melts under heat
