Ok before I buy a morso underpinner that a friends late father has for sale has anyone got anything for sale reasonably local to me..?.. its a new venture but need to produce 60 to 70 frames a week so not really hobbyist.
I cant get any good info on the morso which makes me nervous, so want something easy to get parts for etc.
Many thanks Dave
Under pinner wanted midlands ish !
Daveyo
- Organisation: Market frames
- Interests: Walking
MarkR32
- Organisation: G58 Framing
- Interests: Rugby, Food, Family, Framing
Re: Under pinner wanted midlands ish !
I use the Morso underpinner as a backup for my Alfamacchine 44.
Its ok for the small framer but if your planning on knocking out large quantities, i would look for a more robust model, possibly pneumatic.
The foot pedal on the more is weak and tends to bend around the piston joints, I have had to have it welded and brackets put on to strengthen it. the v nail delivery can get gummed up and the Allen bolts are very soft, so be careful not to round them. the hose can/does/will catch the sharp edges in the foot plate, so be aware and check the condition of the hose regularly.
other than that .. have fun
Daveyo
Just had a play with it..... is there any adjustment like there is on cassese under pinners if the mitres are slightly out? Bit hard to explain but im talking about but where you push the moulding in to the pinner ?MarkR32 wrote:Hi,
The reason I ask the mitres were slightly out ie gap slightly too wide and ive seen there is some adjustment on other under pinners.... Dave
Ps I didnt cut the mitre that was out it was another framer
MarkR32
Hi, no there's no adjustment on this underpinner unfortunately, you mean the adjustable gates found on Alfamacchine's. The cuts have to be good, really good or the gaps will show. I found practise makes perfect between the Morso and the underpinner. The adjustment has to be made on the morso to get the joint right
Daveyo
Thanks for that... i believe there is adjustment on the cassese gates as wel.... well according to you tube.MarkR32 wrote:Hi, no there's no adjustment on this underpinner unfortunately, you mean the adjustable gates found on Alfamacchine's. The cuts have to be good, really good or the gaps will show. I found practise makes perfect between the Morso and the underpinner. The adjustment has to be made on the morso to get the joint right
Im looking more at a pneumatic ones now to be honest the guys after £300 for it so its part way towards a bettwr machine..... d
