WANTED & FOR SALE: Laminator
lawrieh
Organisation: Lawrie
Interests: Web design, photography, cycling, big blue skies and making....
Post by lawrieh »
I have a Hotpress Jetmounter 43" for sale.
The are a few very small nicks (not cuts) in the top roller but they are very shallow and short and dont impact whatsoever. If it wasn't for them I would say it's almost "as new".
Its very well built and a real tank. I think I also have instructions/DVD for it.
I also have a quantity of over laminate films (around 915mm wide) you can have with it. The only reason I am getting rid of it is that I need to laminate 48" wide panels occasionally. I manage this just with the 43" machine by running through twice offset left and right on each run but its not ideal.
If you have a 1200mm or 1400mm hot or cold laminator for sale please let me know, I am looking to buy or swap.
The Jetmounter is available when I can get a larger machine.
Welcome to view in SW9 London.
It fitted in my car (estate) when I bought it so you might be able to collect if your car is suitable. I may be able to deliver if you are reasonably local.
£750 cash.
I will try an upload pictures shortly.
lawrieh
FOR SALE: Laminator Hotpress Jetmounter JM44
Post by lawrieh »
Some photos at last.
Complete with training DVD, Instructions, original fuse (wow!), front feed bar and a full roll of 1040mm x 25 metre 75μ Gloss Pressure Sensitive Laminate. A 50μ (micron) gloss clear PVC film that is coated one side with a highly oxidation, UV and blanch resistant permanent pressure sensitive adhesive. This adhesive is laminated with a 72gsm PE coated siliconised release liner."
Very light use, very well cared for... Could possibly deliver locally. Top comes off the base, I managed to get it in the back of my Passat Estate easily enough...
lawrieh
Re: WANTED & FOR SALE: Laminator
Post by lawrieh »
Price reduced to £650 and I've found some extra over laminate to throw in.
andyb333
Organisation: framing manchester ltd
Interests: Interests Hobbies Pastimes
Post by andyb333 »
Is this still available? Could be interested.
Andy 07947 360460
lawrieh
Post by lawrieh »
Hi Andy
yes it is, I will give you a call in the morning..
LAwrie
lawrieh
Post by lawrieh »
Sold...
