A friend has taken over a storage unit from a retired framer and been left both of these pieces of equipment.
The Ademco press looks like it could do with a test/service as it's been left with its top cover off, suggesting it needs fixing. It looks like a dial is missing too. On the plus side it has a pump with it.
The Keencut looks like it may be missing some parts and needs a good clean.
If there's any interest in either of these pm me or I guess they'll head to landfill..
Any offers considered.
They are both in Cardigan, West Wales.
Justin
Ademco heat vacuum press and Keencut Rondo.
- IMG_20190301_150303.jpg (4.28 MiB) Viewed 1340 times
- IMG_20190301_150752.jpg (523.44 KiB) Viewed 1340 times
Re: Ademco heat vacuum press and Keencut Rondo.
I meant recycled not landfilled, of course.
I had an Ademco press which I have just junked.
If yours will pull a vacuum to over 20psi and the elements all work then you might have good machine. They are a bit sensitive
though and if the lid has been taken off then there's a good chance the seal is compromised.
The missing dial is a timer which can easily be replaced.
