I wonder if anybody can help. My CS20 has stopped
Clamping. The air supply looks good, and nothing jammed as far as I can tell.
The pre-clamp adjustment lever is open and won’t close. Looking a the pedal unit, the top small grey lever appears to be Loose and not doing anything, I’m wondering if that might be the problem?
Any thoughts? I’m stumped right now.
Cassese CS20 Cart Problem
- GeoSpectrum
- 9D702FFA-C1DF-4882-9B92-A1FF4084A94A.jpeg (2.5 MiB) Viewed 1890 times
Re: Cassese CS20 Cart Problem
Alan, very sorry to read about your CS20 problem.
If you do not get it sorted quickly you are very welcome to use my CS89 any time so as not to let customers down. I'm just down the A52 and I would be pleased to see you.
Peter.
Peter.
- Mark Thornton
- Organisation: Underpinner Spares
- Interests: Red wine - lots and lots of it.
Could be the pedal has failed which is becoming a very regular fault on Cassese machines since they started fitting cheap chinese branded pedals to their equipment.
If its under warranty contact your supplier.
Mark
Mark
