Moulding Storage
Posted: Thu 10 Oct, 2019 10:07 pm
by StevenG
Good evening folks - I need to build some moulding storage rack thing wotsit, based on previous discussion it would appear that the best storage solution is vertical. Can I be awfully cheeky and ask for photos (if possible) of existing implementations so I can steal ideas for my own benefit?
I thank you once again
Steven
Re: Moulding Storage
Posted: Fri 11 Oct, 2019 2:26 am
A lot of it depends on the space you have available.
Vertical is good as it's easier to pull lengths out and find stuff. But you need 10ft+ ceilings.
As for warping, it's my exp that if a stick wants to twist it will do - whether is horizontal or vertical.
I have most of mine on chipboard furniture panel shelves with little swivelling 'catchers' screwed to the edges.
Posted: Fri 11 Oct, 2019 7:21 am
by poliopete
Not being capable of uploading photo's I will attempt to explain how I store much of my moulding.
One 10ft length of 2"x12 with 12" lengths screwed from the back at regular intervals at right angles. Assembled on my work bench before securing to the walls. To retain the vertical moulding I use expanding curtain wire, hooks and eyes.
It was very quick and easy to do and works fine.
The rest of my moulding stock lives under the bed/s
Peter.
Posted: Fri 11 Oct, 2019 9:39 am
by JohnMcafee
This was my setup in our last shop. I still have the U shaped brackets which are now lying around gathering dust.
They are free to anyone who can pick them up from the Belfast area
Posted: Fri 11 Oct, 2019 7:28 pm
by poliopete
Very sorry, my 10ft length should read 2" x 1" and not 2" x 12
Peter.
Posted: Sat 12 Oct, 2019 11:51 am
by Abacus
Here’s mine.
3” x 2” screwed to the wall with holes drilled in to take 1” dowelling.
The under storage has a lip on it to try to stop the moulding walking.
Posted: Sat 12 Oct, 2019 11:53 am
by Abacus
I’ve recently constructed this overflow rack.
Posted: Sat 12 Oct, 2019 1:45 pm
by StevenG
Hi Folks
Thanks for all the replies, it's greatly appreciated
Yes, I do have the height, I reckon my ceiling (well it's the roof of the building) is about 25-30ft. The warping regardless of the storage method is probably true but I find gaining access to a piece that's buried under 10 layers is rage inducing especially when I damage something in the process so hopefully the vertical option will help.
Those photos do help a lot and thanks for the offer John - I'll try and get something sorted for that
It's a crazy time here at the moment, I'm about 3 weeks behind with framing orders but the premises is slowly getting to a point where I can have customers again, I hope to get the shop organised this week and the workshop shortly after.
Thanks again for all the advice
Steven
