Am I a bit unusual having a band saw in my workshop?
I find my band saw extremely useful when making up unusual profiles by cutting and joining bits cut of from different moulding profile and then rejoining them to create completely different profiles. Does anyone else use a band saw in their framing workshop? There is certainly not a lot of evidence that this is the case. Was just wondering! Surely I am not the only forum member regularly using a band saw in his framing workshop.
Re: Am I a bit unusual haiving a band saw in my workshop?
I would have one if I had the space. Also a planer/thicknesser. :D
That's on the list for me too! I'd like one of the combination planner thicknessers and joiner plane all in one. Their not all that expensive, so maybe one day I'll be able to get one.
Re: Am I a bit unusual having a band saw in my workshop?
I've recently been lent a bandsaw for my workshop.
I've found it really useful for customising/making spacers from offcuts.
I've managed to keep the dusty tools in a separate garden shed workshop.
Tudor Rose
Organisation: The Framing Lot
Post by Tudor Rose »
We're very lucky because not only do we have a lot of "toys" (sorry, tools!) in our own workshop, plus a fully functioning woodworking workshop that my Dad has at his house that we regularly take advantage of using his pillar drills and bandsaw and the like. But we are also next door to a bespoke staircase manufacturer. They do us innumerable favours throughout the year running mouldings and lengths of wood through their spindle cutters, thicknesser and table saw. We've been able to make all sorts of unique construction pieces thanks to the variety of machines and tools we have available to us. It makes a huge difference.
Justin is right to mention the dust - we have a dedicated room for "dusty" work that we built a few years ago, it is also soundproofed. Keeping things separate saves time and effort.
GeoSpectrum
Post by GeoSpectrum »
I have a bandsaw also a table router, belt sander and CNC as well as the a mitre saw, Keencut 5000, underpinner and mount cutter. You just can’t have enough kit.
Too right. You not only can't have enough kit, but some of my kit, I am even thinking of replacing with better kit. It's only after you have had your original kit that you realise some of the limitations that you did not realise when you first bought it.
fusionframer
Interests: framing
Post by fusionframer »
I have a bandsaw. I use it for framing, but probably use my tablesaw and planer thicknesser more to be fair.
I have a full joinery workshop, so my table saw is a great big cast iron panel saw, so has very accurate fence etc. I guess. I tend to use my bandsaw for ripping timber so keep a 1 inch blade on normally.
Obviously, i a lucky that doing joinery as well means i have access to serious toys (i mean machines), but i do use both the morso and sometimes underpinner for joinery jobs.
The big machines just can't be compared to cheaper models in terms of accuracy and speed to do things, but some smaller kit is perfect for some jobs.
Btw (sorry soapbox moment) even if using good dust extraction (i have a industrial rated extraction system), please try to remember to wear some form of face mask.
The number of woodworkers in 60's plus who have retired due to COPD is frightening. I have a proper respirator, but it is a pain, so i didn't bother much, but now keep this around my neck:
They are handy and i remember to use it even when sanding. Also, it can look like you are wearing a cravate in case a discerning customer comes in!
Cheers Nick
www.fusionframing.co.uk
fusionframer
Interests: framing
Also, i do have a spindle moulder so if anyone gets stuck trying to match a moulding, i may be able to run off some if needed. I know trying to get small amounts done is hard.
Nick
