Hi framers,
I'm in the process of re-designing my workshop and buying in new equipment. I'm hoping to get a minigraf 4 and build a worktop around it, but need to know the height of the flat surface of the machine before I go confirming any figures. Do they even come on stands? And if so are they adjustable?
Thanks in advance
Esther
height of minigraf 4?
Re: height of minigraf 4?
I would suggest that the height of your table is the most important detail. For me a comfortable working height is 100cms. My underpinner height is 92cms, so it is on 8cms blocks.
The minigraf 4 does come as a unit without a stand, 130mm high which could be built into the workbench (no I can't find the stand height either).
For the sake of your back, have a look at a few work bench heights and see which feels best for you. I stand up for most of the day, any lower than right would hurt after a while!
- Organisation: Hidden
- Interests: Art, framing, music
Thank you so much, that's really helpful. I'll go ahead and start building then
