System 4000 vs. Excalibur 5000
Hi folks -
I'm looking to round out my framing workshop with one of these (or some other brand - these are the only two I've had recommended).
What are the major differences? I've been warned off the Excalibur by one or two people saying it's not as good as the older System 4000. Never having used either - what would you recommend?
Cheers,
Peter
Cheers,
Peter
- John
- Site Admin
- Interests: Forums and stuff
Hi Peter, welcome to the forum.
Probably not a lot of framers will have in-depth experience of both machines.
We bought our Excalibur 5000 four years ago from Lion. In that time we had to replace a spring within the cutting head, which was supplied by Keencut free of charge.
It has served us well, handling MDF, glass, mountboard, and foamcore without any problems. We have no regrets.
HOW Much!?
We had a system 4000 for many years and it served us very well as a board and glass cutter. We brought a new Excalibur 5000 a few years ago which again is a very good machine. The 5000 has two cutting heads and also has a scoring blade which is very useful for cutting perspex.
Personally I prefer the newer model.
Are you buying new or used??
Hi Peter. We've had our System 4000 from new for 16 years man and boy or is that woman and girl. It has survived 2 moves. I think we have replaced the MDF head twice. Keencut have sent the odd replacement part free of charge and are extremely helpful with any technical problems. I did have a bit of bother with the counterbalance falling out when I was a bit heavy handed in the early years, but rigged up a system for fixing it that takes seconds. A bit of lubrication, blade changing and the odd glass wheel change and it still operates as well as it did 16 years ago. Some of my staff complain it isn't accurate in cutting but I blame user error as it performs perfectly for me. I certainly couldn't run my business without it. Never could cut in a straight line with a hand held glass cutter
- Interests: Pubs
- Interests: 4 or 5 ...
- David
Hi Peter
Guess who's got a 4000?
I put it in storage a couple of years ago when we closed one of our outlets, we already had a 5000.
Overall I think I prefer the 4000 especially when I got smacked on the head from the cutting head on the 5000. If I'd got the time I probably would have swaped them and it's why I've held on to it, but it is taking up space or if you'd prefer the 5000???? Open to offers.
Both in excellent condition. I'm in Surrey not sure where you are.
Get in touch if you are interested especially if you are close by.
All the best.
David.
All the best.
David.
- MITREMAN
Re: System 4000 vs. Excalibur 5000
Hi Peter,petercox wrote:Hi folks -
Cheers,
Peter
The new Excalibur 5000, is basically the same frame as the 4000 but with a much improved cutting head, a very good machine
TECHNICAL DATA
Cutting Capacity KE01 & KE03 - 1220mm (48")
Cutting Capacity KE02 & KE04 - 1600mm (63")
Glass / Mirror up to 6mm thick
Mat / Foam / Corrugated cardboard up to 13mm
Hardboard / MDF up to 3mm thick
Plastics / Acrylics up to 6mm
Fracture Sensitive Materials up to 6mm
Gross Weight 1220mm - 56kg, 1600mm - 67kg
Also consider the Flecther Terry Wall Mounted Glass and Board Cutter 3100.
TECHNICAL DATA
Cutting Capacity 1600mm (63")
Glass / Mirror up to 6mm (1/4")
Mat Board / Foam Board / Gator Board up to 12mm (1/2")
Hardboard up to 3mm (3/32")
Scoring Plastics / Acrylics / Fracture Sensitive Materials up to 6mm (1/4")
Aluminum up to .040" thick (Optional accessory required)
The best way is to try before you buy, had you gone to Birmingham these machines would have been on display for you to try. Framers Equipment in Northampton Tel:01604 790333 have both these machines on display with materials for you to play with and compare for youself, both give good cuts, its a matter of personal choice.
MITREMAN says "Try before you buy"
Cheers MITREMAN
