Morso bolt sizes
newie31
- Organisation: Frames
- Interests: Caricature
Morso bolt sizes
I'm going to collect a Morso tomorrow, not sure if the spanner is available and I need to remove the r/h arm for transport, can some have a quick look at their morso and let me know the size of the head so I can take the right ring spanner with me? Cheers,Mark
theframer
- Interests: football,fishing
Re: Morso bolt sizes
Not in the workshop so i cant measure it but from memory i think its 17mm
Dave
Dave
Dave
www.iconframers.com/
Mine is 16mm. The blades spanner is 17mm.
cleaver
- Interests: .
If it's going in a car, put the heavy end (top) nearest to where you'll get it out of the car.
Also, it's a great help to have a sheet of 18mm MDF or similar already in the back of the car to lay it on, as it'll slide in and out more easily on it. If you take offcuts of something like 3x2, you can screw these onto the sheet and tight against the Morso, so stop it sliding around.
Good luck
Good luck
newie31
Thanks for all the replies, safely collected
