bbest
greenfields
bbest
Post by greenfields »
hi i am looking to get a box frame in the bbest system i put in the number of the inside moulding then the outside one but the price never seems to go up then i get this popup which says the frame is not on the table of frames i have down loaded from aq siss and simons what mistake am i making
John
Site Admin
Organisation: Tech Support
Interests: Forums and stuff
Post by John »
Setting up a table of stocked mouldings makes your life a lot easier when it comes to stacked frames as it allows you to define your own name for each moulding that you stock.
Say you were pricing a job that had three stacked frames.
Innermost: Arqadia 308244358
Then: Sisslings 480-Antique
Outer: Simons APOL/0012
If you have not set up your table of stocked mouldings, then in order to price the frame, you must enter
"AQ.308244358+SS.480-Antique+SI.APOL/0012"
(without the quotes)
Y
Also, you must enter this in a continuous flow, because if you pause for too long the program will think that you have finished, and if it doesn't understand the entry up to that point, you get the pop-up you describe.
On the other hand, if when creating your table of stocked mouldings, you gave each of these mouldings a brief name (My Id.). For example: -
For AQ.308244358 My Id = 123
SS.480-Antique My Id = 87
SI.APOL/0012 My Id = 16
Then pricing your job is a snap, you just enter
"123+87+16"
