backing board is too small
sarah1
Organisation: nobusinessyet
Interests: Art, cooking and pets.
Post by sarah1 »
Hi everyone,
I've been asked to frame something that it much larger than I normally frame. It's 100cm x 120cm. I've just checked my mdf backing boards and they're not large enough. I rang the suppliers and they only have that size. Any suggestions?
Gesso&Bole
Re: backing board is too small
Post by Gesso&Bole »
There are a number of options, what is it you are framing?
sarah1
Post by sarah1 »
Thanks for the quick reply. It's a map which is thick. 100 cm x 120 cm.
JonathanB
Post by JonathanB »
Wessex do MDF in up to 2500 x 1240 and also offer a cut to size service from their Leatherhead branch if you don't do large items too often. Similar sizes available in foam centred board.
Jonathan Birch GCF (APF)
Gesso&Bole
You can get MDF in 8ft by 4ft sheets at B&Q or timber merchants. B&Q will cut to size. Otherwise get a large sheet of foamcor
I keep a few sheets of 6x4' MDF for those awkward big jobs. They happen to be the exact size of my benchtop as well
so make good working surfaces. :D
I get oversized MDF cut to size by my local hardware shop. It's so much easier that cutting it myself. I though that was probably what we all did!
