cassesse cs88
paige3
Organisation: nill
Interests: pidture framing
cassesse cs88
Post by paige3 »
Hi could someone tell me the name of the cable and its function , it below the screw that i am pointing at see picture.
Re: cassesse cs88
The cable actuates the rebate clamp. There's also a spring which is sumething to do with the rebate clamp.
David McCormack
Organisation: Framing
Re: cassesse cs88
Post by David McCormack »
As Mark says, it operates the rebate clamp when you use the foot pedal to hold the moulding against the fences. If you need spare parts the codes are:
Spring Z12
Outer cable Z1428
Inner cable Z1539
I think Wessex stock the spring and you could try https://www.underpinner-spares.co.uk for the cables or https://www.ukframingsupplies.net
:D
paige3
Organisation: nill
Re: cassesse cs88
Post by paige3 »
thanks for replying, much appreciated.
