Chinese plastic canvases
Ultima Thule
Organisation: retail framer
Interests: reading ,real ale, music
Post by Ultima Thule »
I have a set of these to do and was advised via an American group to use Mount Cor. Is this available in the UK or is there an alternative that would do the job. It is a low temp adhesive board.
Re: Chinese plastic canvases
I've not even heard of it. I don't think that it available iin the UK.
Have a look in the wessex catalogue, they have the Larson Juhl range of fastmount boards. The Permanent Mounting Board is designed for textiles.
Ultima Thule
Thanks. I have some KoolTak that I might try and of that doesn't work then I'll get something from Wessex. It being December time is of the essence of course.... :roll: Spray adhesive plus a cold spell in the vacuum press was another suggestion but I use sprays as a very much last option.
Fruitini
Organisation: Original Glory
Post by Fruitini »
PUB112 MountCor Canvas.pdf
(175.58 KiB) Downloaded 46 times
MountCor Canvas (& Paper) is available through Lion. Should work a treat. Big thumbs up for Kool Tack also. A great product. Not tested either with the plasticy type of canvases though.
https://www.lionpic.co.uk/p/41283/Moun ... rd-1-sheet
