Dry mount plastic "canvas"?
Jon_Brooke
Organisation: Picture Frame Workshop
Interests: Running
Post by Jon_Brooke »
A customer would like some posters that have been printed onto a plastic canvas framed under glass.
The posters bleed off the canvas so there is no way to stretch them. But they also have some slight wrinkling (looks like cockling would on paper) so I would like to dry mount them.
Normally I dry mount using a heat press but would that melt the "canvas"? Alas I don't have one to practice on.
Or could I use spray mount?
Thanks,
Jon
Re: Dry mount plastic "canvas"?
Post by JFeig »
Are you saying that it is decorative art and of no intrinsic value?
Not knowing the actual type of plastic and its melting point is a crap shoot for heated dry mounting.
The same is true with the use of adhesives and the ability to permanently stick the plastic canvas.
Jon_Brooke
Interests: Running
Yes - minimal value so no need for reversibility.
Actually, I found another thread on a similar subject where people were suggesting Fastmount so I might try that.
I've got an old manually operated roller laminating machine and it works just fine when mounting, when using twin release cold mounting films to mount plastic media. Mind you there's a really big difference in results between using a proper roller laminator at just doing it by hand. I only ever used the basic twin release film from Lion and so I was not using anything special. It works well if the media is nice, clean and free from greasy finger marks before moulting. Greasy finger marks are a definite issue, better safe than sorry. Make sure it is clean and free from grease!
JonathanB
Post by JonathanB »
I recently mounted some cheap prints that were printed on a flimsy, canvas like material to display board using double sided mount film and two passes through my Jet Mounter. I should stress that the items were cheap, easily replaced and the client wanted a basic Level 4 approach to the job. They bonded really well, but I don’t think I could have got the same effect with spray mount and a hand roller. Looking at the material, I don’t think I’d have gone anywhere near it with heat.
Jonathan Birch GCF (APF)
YPF
Post by YPF »
For this sort of job we lay the ‘canvas’ onto 3mm self adhesive board and then stick it in a cold Hotpress for 30 seconds of full vacuum (no heat)
Steve
Chief Coffee Drinker
Whatever you do don't use Spraymount. :shock:
Give Steve Goodall at Wessex Oldham branch a call. He will be able to advise on temp and time for Hotpressing.
Ultima Thule
Organisation: retail framer
Interests: reading ,real ale, music
Post by Ultima Thule »
Following posts on a FB page I have been using Mount Cor successfully for these cheap "canvases". It is American but Lion sell it, along with instructions, and it bonds them perfectly.
The Hotpress "Dry Mount Film - Clear" supplied by Wessex is designed for canvas mounting, but it doesn't mention a temperature point for curing... Steve will know.
