Framed oil canvas with glass
AtelierFrames
Organisation: Atelier Frames
Interests: Arts, crafts, sports, outdoors
Post by AtelierFrames »
A customer has requested a number of oil paintings on stretched canvas to be framed under glass. I have explained they would need a spacer or slip frame so that the painting does not come into contact with the glass . However, would I put a backing board on the back or leave this open for the canvas to breath.
Re: Framed oil canvas with glass
"Canvas doesn't breathe!" is a common exclamation on other forums.
As I understand it, it is common practice in the US to back a canvas with a corrugated polyproplene board, but not common in the UK. Personally I like the idea but would take my lead from someone like Tudor Rose.
I can say however that when framing a canvas it is advised to use Acrylic rather than glass, due to the high likelihood of costly damage to the canvas should the glass break.
AtelierFrames
Thanks for the prompt response. I will check out the other threads on yhe forum as you suggest.
Also, a valid point about potential damage to canvas should the glass break.
Your feedback is very much appreciated.
"...on other forums.." was referring to Framers Only/framing.academy groups etc on facebook.
