Framing seaweed
Machiners2
Organisation: Machin & Machin
Interests: Walking, bridge, sewing, golf, theatre and comedy
Framing seaweed
Post by Machiners2 »
Has anyone been asked to frame dried pressed seaweed - seems to be a new trend! Someone has asked me if I can do it, but having never done any the answer is I don’t know! Not sure how to stick it. Could it touch the glass? A box frame probably best I would imagine. Any other potential issues? Thanks for any advice :)
GeoSpectrum
Re: Framing seaweed
Post by GeoSpectrum »
A recipie for rot or dried out in pieces at the bottom of the frame?
Re: Framing seaweed
Anything is possible! A few dots of water based grab adhesive or even clear drying wood glue should do the trick. I wouldn't put it against the glass as the temp and humidity is bound to affect it sooner or later. Just use a spacer (as in a box frame). Warn the customer that this is bound to deteriorate in time.
Gesso&Bole
Re: Framing seaweed
Post by Gesso&Bole »
There's no problem with framing things that will deteriorate, so long as the customer understands the reality.
I have done quite a few wedding bouquets over the years - one being my daughter's which was 10 years ago and still looks good, in a Miss Haversham sort of way!
The trick is to design the frame in such a way so that if (and when) bits fall off, they are not too obvious. The easiest way to do this is in a box frame with a mount at the front.
