Wedges not being driven in flush with back of frame surface
Posted: Mon 20 Feb, 2023 11:35 pm
by boscawen46
Hello,
I have a Minigraf 4 underpinner that has served me well. Recently I changed the wedge hammer / piston unit because the old one was about ten years old. It was beginning to not drive wedges in fully. The new hammer is much better but the wedges are still not driving in fully. I have the bar pressure up to about 5.5 and don't want to go further in case of damaging the polycore moulding.
Does anyone have any advice to rectify this.
Re: Wedges not being driven in flush with back of frame surface
Posted: Tue 21 Feb, 2023 9:35 am
by pramsay13
Are the wedges definitely the correct type for polycore and are they in the correct way?
If the pressure is up that high and still not firing in fully something else is wrong.
Have you tried with some wood just to check?
I don't use plastic moulding so not sure what is different.
Posted: Tue 21 Feb, 2023 7:11 pm
by Folly framing
You might try ringing Will at lions? he's on their machinery team and could probably advise. He can tell you any parts you might need and if you cannot fix it over the phone you can send it to them in Birmingham to fix. They helped with my machine and were great.
Posted: Tue 21 Feb, 2023 10:45 pm
by boscawen46
Thanks both of you for your advice. The wedges are definitely the right way up. Pressure is at about 6 bar because polycore is not that hard.
Will ring Joe at Simon's.
Posted: Tue 21 Feb, 2023 11:14 pm
by StevenG
Joe doesn't work at Simons anymore!
Posted: Wed 22 Feb, 2023 5:00 pm
by JFeig
My first thought is an air leak somewhere in the system. Have you tested for air leaks at all the connections? It is an easy test with soapy water and a brush.
An alternative idea is, had this machine had regular maintenance with "pneumatic lubrication oil" ? If not, there could be some sticking valves, possibly in the foot valve switch. The o-rings could also co bad without proper lubrication. Do noy use any other type of oil.
Posted: Thu 23 Feb, 2023 10:18 pm
by boscawen46
Thanks again
