morso
rich0410
Organisation: blackheath frames
Interests: framing!
morso
Post by rich0410 »
rich0410
Interests: framing!
Re: morso
Post by rich0410 »
hi all
is there a tool for this screw or is it just a pair of pliers to loosen?
both are jammed and i didnt want to damage the knurling if there is a tool
novice i know!!
thanks in advance
Re: morso
Post by vintage frames »
That's an Allen Key screw.
Most hardware shops will sell you a set, usually on a key-ring.
Just pop the one, the right size, into the centre hole and turn. Might be tight but little or no chance of damaging the screw.
Re: morso
A squirt or two with WD-40 would help. :D
rich0410
Interests: framing!
Re: morso
Post by rich0410 »
thank you guys
i thought it was too round to be an allen key,
will give it a go
