Morso miter cut not going all the way help
Posted: Thu 20 Apr, 2023 1:19 pm
by fallguy
May sound a silly question but my Morso has started not completing the final cut and leaves a small bit at the bottom back of the moulding (see photo) and for the life of me I can't work out what to adjust to make it a clean cut all the way through, it's had a recently sharpened set of blades fitted but I don't think that's the problem and advice would be welcomed
thanks in advance
Re: Morso miter cut not going all the way help
Posted: Thu 20 Apr, 2023 2:35 pm
by Mark Thornton
The setting is mentioned in the later versions of the manual.
Mark
Posted: Thu 20 Apr, 2023 3:06 pm
by JKX
And here’s the manual!
https://www.thegrumble.com/data/manuals ... tsList.pdf
First check there’s nothing obstructing the foot pedal though - and the moving parts inside - sometimes shavings can get trapped and cause problems.
Blades wear down when they are sharpened. so it may be a case if adjusting downward travel with the threaded rod attached to the blade housing - should all be in the manual.
Posted: Sat 22 Apr, 2023 12:03 pm
by fallguy
Many thanks for the reply's will see if i can sort as directed.
