Gielle 4000e Pneumatic Underpinner & Stand £150
Bought for a project which is no longer possible - it's a really well made and heavy machine - will probably need a service before use as has stood for a year so selling as spares or repairs - comes with a box of bits including moulding wings, wedges, instructions and is complete with the tilting stand. I have not tested it or used it in any way.
Collect from Devon - extremely heavy machine. Please DM if you have any questions.
Operation - GIELLE 4000E
SIMPLY THE BEST PNEUMATIC FRAME ASSEMBLING MACHINE IN ITS CATEGORY IN THE WORLD MARKET
PNEUMATIC FRAME ASSEMBLING MACHINE PARTICULARLY SUITABLE WITH MEDIUM AND LARGE FRAMES AND WHEN IT IS REQUIRED A QUICK AND FREQUENT SIZE ADJUSTEMENT. VERY SOLID MACHINE, IT IS EQUIPPED WITH A V NAIL DRIVER SET ON A MOVABLE CARRIAGE CONTROLLED BY THE OPERATOR THANKS TO A JOYSTICK. IT ALLOWS A QUICK INSERTION OF V NAILS IN DIFFERENT POSITIONS. THE PNEUMATIC PEDAL WITH SAFETY SYSTEM CONTROLS THE PRESSURE ARM IN ORDER TO PRESS THE MOULDING ON THE WORKING DESK. THE WEDGES ARE INSERTED BY PRESSING THE JOYSTICK BUTTON. THE PRESSURE LEVELS ARE DISPLAYED ON FIVE MANOMETERS. A 600 VNAILS LOADER (A PNEUMATIC VALVE
OPENS IT QUICKLY) ALLOWS THE OPERATOR TO SAVE TIME IN CHARGING V NAILS. TWO HYDRAULIC PRESSURE ARMS ALLOW TO FRAME ALSO BIG SIZED AND SHAPED MOULDINGS. IT IS POSSIBLE TO OPERATE WITH A PRESSURE ARM ONLY, IN ORDER TO FRAME SMALL MOULDINGS. VERTICAL (PRESSURE ARMS), FRONTAL (CLAMP) AND BACK (A BRAKE) LOCKING DEVICES ALLOW A PERFECT LOCK OF THE MOULDINGS, PARTICULARLY IN ORDER TO INSERT EASILY MORE VNAILS IN SEQUENCE IN THE SAME POSITION.
