fixing mirror in frame
red
Organisation: none
Interests: woodwork
Post by red »
what is is preferred way to fix mirror in a frame?
thanks
Gesso&Bole
Re: fixing mirror in frame
Post by Gesso&Bole »
Depends rather on what sort of size you are talking about, and what sort of frame.
On something heavy, with enough space in the rebate, I'd use a sub-frame, and screw that in.
Otherwise if it's small/stable enough, put a board behind it and then use framers points.
Post by JFeig »
Traditionally, wedges of wood were placed between the edge of the mirror and the outside lip of the rebate. The individual wedges were secured with a single nail into the frame at an angle. The 90°edge of the mirror would "grab" onto the softer glass of the mirror.
One nice touch is to black out the underside of the rebate with a fat marker. This prevents the edge of the mirror
reflecting any scruffy bits. It looks cleaner. :D
red
Organisation: none
Interests: woodwork
Post by red »
many thanks
You can use Volara tape in the rebate too, to cushion it and black out the rebate.
