self adhesive boards
dougie
Post by dougie »
new here so hi everyone,im having problems with adhesive boards not sticking too good,my workshop is a bit on the cold side,will this affect it?had a couple of pieces returned with bubbles and reluctant to use it till i figure it out,any advice would be welcome. ps. any one had to do an ordanance survey map that comes flat with a funny coating both sides?nightmare
John
Site Admin
Organisation: Tech Support
Interests: Forums and stuff
Post by John »
Hi Dougie
Welcome to the forum.
We often use our press (flat bed) to help bond items to the sticky board, specially for anything that is well creased, or seems a bit 'plasticky' that we feel might not adhere too well with just the roller.
Moglet
Organisation: An Urban Myth
Post by Moglet »
Hi Dougie and welcome to you! :)
What type of board are you using at present? I have found that, of the boards I've tried, some have a much higher grab than others (Arqadia's Fastmount Permanent in particular).
........Áine JGF SGF FTB
dougie
Post by dougie »
cheers for them,unfortunatley dont have a press yet,something to look at,been using xtra-tak and fastmount and had probs with both
Moglet
Post by Moglet »
Dougie, have you tried dry mounting stuff in a location other than your workshop?
Re: self adhesive boards
dougie wrote:new here so hi everyone,im having problems with adhesive boards not sticking too good,my workshop is a bit on the cold side,will this affect it?
Hi Dougie,
Yes, all self-adhesives are to some extent subject to variations in perforance with variations in temperature. Perhaps the manufacturer may be able to supply you with some kind of data sheet to help you.
Also you should be aware that all self-adhesive products have a shelf life and old stock can become a problem to you.
dougie wrote:had a couple of pieces returned with bubbles and reluctant to use it till i figure it out,any advice would be welcome.
Where I was trained they used self-adhesive mountboard for almost all dry mounting, but they always put it into a heated press at 60 degrees. This not only helped the adhesion, but also resulted in driving out any trapped air by expansion. After cooling any remaining air shrinks with the drop in temperature to even less.
Something seems to happen to self-adhesive boards in a heated press which appears to increase the bond strength.
dougie wrote:any one had to do an ordanance survey map that comes flat with a funny coating both sides?nightmare
Some rolled Ordinance Survey maps are specially printed to order by a wide format ink-jet printer. The surface coating on ink-jet papers can be problematic with self adhesive mountboards if not applied in a heated press. The paper tends to lift, perhaps because it may be trying to return to the rolled state in which it was supplied.
It is worth noting that self-adhesives are not refered to as pressure sensitive adhesive for nothing. This is because the bond strength can be greatly dependant upon the degree of pressure applied at the time of application. This is why roller presses are popular with so many who use self-adhesive mounting.
kev@frames
Interests: 4 or 5 ...
Post by kev@frames »
the cold does not hep at all. Other than warming up the board or keeping it somewhere warm dont have much of a suggestion to help with that one.
Lots of pressure, and warmth from your hands (use the release paper on top if rolling etc) can help.
Agree that the one which seems to have the best overall grab is Arquadia. Very useful. And very permanent - it keeps my restorer in work he says ;) A customers poster (rolled) once rolled over the workbench anmd attached itself firmly to a scrap of the stuff :(
Crescent also do an acid free (conservaton it says on the box) version, which has a very good grab as well. Available from wessex or your usual suspects.
Moglet
Post by Moglet »
kev@frames wrote:A customers poster (rolled) once rolled over the workbench anmd attached itself firmly to a scrap of the stuff :(
Oh nightmare, Kev! :shock:
kev@frames
it was a nightmare for sure when i got the restorers bill :(
osgood
Post by osgood »
kev@frames wrote:it was a nightmare for sure when i got the restorers bill :(
I keep a small bottle of 'Un-do' which is a liquid that dissolves adhesives. I have used it for getting stickers off the back of photos and it would probably have done the trick for you with that accident. Perhaps you might be able to get some in the UK somewhere.
Someone on The Grumble suggested that Naptha or lighter fluid might also work. Must get some and give it a try.
kev@frames
yeah i have heard of Un-Do (seen it on the grumble). But not found any here, yet.
I do have some zippo fluid, but i wasn't happy experimenting with it on someone's job.
I find its less complicated to come out with my hands up, step into the searchlight and tell them I'm having it professionally restored :(
once, in the olden days, i had a biro mark taken off a photo, which i thought must have been someone's fault at our end. When the customer picked it up, he was amazed that I had "had it fixed" for them. He'd brought it in like that with a biro mark on.....
"all part of the service", says I through gritted teeth.
Spit
Organisation: Framing Mad
Post by Spit »
Zippo fluid works fine where the adhesive is thin (labels & the like) and certain tapes. With heavier duty tapes like duct tape and some masking tapes while it thins the adhesive and allows you to remove the tape, it doesn't necessarily remove the adhesive - you can be left with a sticky residue that gets everywhere! A lot depends on the surface too - glossy ones are obviously easier than others.
Steve.
fineedge
Post by fineedge »
Lady friend once came into the work shop, we chatted, she counted out her money and put it on workbench, we chatted, she left, I forgot about money and carried on working with mounts and later discovered the money lying on sticky board ready for use (release paper off). Tore one R50 note to bits
Alan
fineedge wrote:later discovered the money lying on sticky board ready for use (release paper off). Tore one R50 note to bits
You were a bit slow there - you shoulda carefully cut around it, stuck another to the back and put an elastic band around it - passed it off as a wad.
kev@frames
fineedge wrote:.......Tore one R50 note to bits
thats almost a pound ;)
dougie
Post by dougie »
cheers for the answers,have been using a hot air gun to warm the card on smaller pieces,seems ok but wasnt sure if that would affect the adhesion
fineedge
Post by fineedge »
_________________
just over 3 at current rates. Hell we all know we got mickey mouse money over here!
Alan
Bill Henry
Post by Bill Henry »
It sounds like it has been coated/sealed with a material similar to what we call Tyvek – a material that is often used in housing construction. This material is frequently used for nautical charts.
The material is virtually waterproof, designed not to tear, and, I think, it is also has a fire retardant chemical in it. One can fold it easily and, once unfolded, the “creases” aren’t quite as permanent as they would be if it were paper.
If this what I am thinking of, placing it in a heat press will compound your misery. Under heat, it crinkles so much that the surface is distorted. Once done, I have found them nearly impossible to flatten.
Moglet
Post by Moglet »
Bill Henry wrote:It sounds like it has been coated/sealed with a material similar to what we call Tyvek ...
Tyvek is also used for printed labels on plants in nurseries.
Years ago, a company I worked for supplied a dot matrix printer to a local nursery for a plant label printing application, and we had to specially source printer ribbons with an acidic ink that would etch the printed characters into the Tyvek surface. Regular ink just beaded on it. Wouldn't surprise me if there were adhesion problems when trying to drymount the stuff. :?
Steve Goodall
Post by Steve Goodall »
Reference Un-Du... Manufactured in the "good ole" USA - highly toxic - cannot be shipped (legally) into Europe - pity really - the smell alone gets you as "high as kite".
Reference Adhesive Board... Contact Hot Press 0117 958 6500 & ask for a sample of their "Stikiboard" - yes it really is called that!!! It is very high tack & does not "pretend to be repositional" - you touch your work down & it is stuck - but that is what you want & need.
Reference PMA... Made by 3M. Only available up to 16" wide. Designed for "office applications" rather than professional use. Hot Press do a product called Double sided mount film - available upto 51" wide - again - ask them for a sample...
