Framers triangle points!
Martock
Organisation: Martock Gallery
Interests: Picture framing, handcrafting mirrors and gifts
Post by Martock »
Good morning
We use these triangles occasionally when the frame fit is too tight for our standard gun/points - they are fitted by hand … does anyone have any squirrelled away by any chance or know where I could buy them? Many thanks!
Re: Framers triangle points!
Lion do (did do) Fletcher 11mm ones.
But if you take my advice, invest in a Fletcher Multipoint gun. Excellent for 'shoehorn' jobs. :D
Gesso&Bole
Post by Gesso&Bole »
I agree, I have only used my multi point gun a handful of times in the last few years, but when you need it you need it!
I'm shuddering thinking about cuts from removing rusty triangle points... :x
StevenG
Post by StevenG »
Justintime wrote: Thu 19 Oct, 2023 11:32 am I'm shuddering thinking about cuts from removing rusty triangle points... :x
Yip
Post by JFeig »
Those are long obsolete "glazers points". I agree that you should be updating your supplies. The Fletcher Terry part number is 08-511 if they are still available. They are loose packed and do not fit into a fitting tool; thus, they are not as safe to use.
Martock
Post by Martock »
Thank you every one for taking the time to reply! We’ll have to encourage change within the business 🤣
Are they the larger 13mm triangle points, for the old Kaha point guns. I've got some, but I need to look for them, because I don't know where they are. They come in a thin metal sleeve, and you withdraw the sleeve after the points are in the gun. The 13mm points are to large to for other guns point guns. I'm not that far from you in Devon.
I use Multi points for everything. They hold well. They are nice and thin and can be bent without springing back.
They are also handy for joining stacked sections when the inner part protrudes - band one in and put a small screw in the hole.
They are easy to remove. :D
I never like the conventional framers points (Green gun).
