hanging fittings
Compomouldings
Organisation: Compo mouldings ltd
Interests: Framing
hanging fittings
Post by Compomouldings »
i will need to fix a large frame weighing around 50-60kg flush against a wall.
What would be the best fixings to use
MAny thanks
Michael
Re: hanging fittings
Post by JFeig »
Wall anchors. They will vary depending on the type of wall the art is being installed on.
For the frame, the stronger the better for the hardware. Multi- screw metal plates with secure welded on rings (AKA "D" hooks) or bent plates with holes. Do not skimp on the quality or size of the screws.
Compomouldings
Interests: Framing
thank you all
Timh
Post by Timh »
Split batten would work as well if there's enough room in the rebate
