Trying to source the supplier of this moulding used for a box frame to put baby hand and feet castings into.
The molding depth is 54mm and the width is 10mm its bare wood with a rebate.
Any suggestions please.
Identifying a frame
FandLframes
- Organisation: F and L Frames
- Interests: We are in the process of buying a small framing business and we are looking for help and advice!
Identifying a frame
Re: Identifying a frame
Is there a rebate on the bottom as well as the top?
That appears to be a raw timber "extender". It can be made in any woodworking shop with the simplest of tools, a hand saw and a plane.
A table saw can cut basic wood to width needed as well as the rebate. The mitered ends can be cut with the same saw or a dedicated miter saw.
FandLframes
No only rebate on one side. we do make similar versions but wondered if there was an option to buy a ready made length of these to create boxes for newborn casts etc
Have a word with these guys....
http://www.norfolkmouldings.co.uk/
I have found them are very good and min order only 100ft. Quick turn around.
The profile is simple and won't need special knives to be made.
It could be that the width is 54mm and the depth is 10mm - but it’s mitred on its side.
