Hotpress HGP360 Vaccuum Press with Stand for Sale
Patrick2012
Organisation: Brighton Framing
Interests: Framing
Post by Patrick2012 »
Due to downsizingand because we still have the smaller 260 model, we are selling this Hotpress HGP 360 Vacuum Press with stand which is not shown in the photos
Very little use, as most stuff is done on the smaller press.
Collection from Hove , need at least 2 people to lift and a van of course
£1800 or nearest offer [around £6,000 new]
HGP 360 Hot Press Glass Vacuum Press - Picture Framing - Mounting. perfect working condition, comes with pump and the original
stand which is optional usually is available we used it on a heavy duty work bench . We have the 260 still , 360 hardly used as small
items cover 95% of what we do
HGP 360 Vacuum Press - Patent No 2222985 UK
Hot press for use in print and picture framing.
Hardly used.
Overall Size 39” x 51”
(975 mm x 1300 mm)
47” x 71”
(1194 mm x 1800 mm)
Diaphragm Working Area 35” x 47”
(890 mm x 1194 mm)
42.5” x 66.5”
(1080 mm x 1689 mm)
Time to Vacuum 20 sec 30 sec
Time to Temp 12 min 12 min
Voltage 220V single phase;
50/60 Hz
220V single phase;
50/60 Hz
Wattage 2.5KW 4.2KW
Current 11/13 amp 18/22 amp
Weight - Net/Shipping 159 lbs (72 kg) /
198 lbs (90 kg)
244 lbs (111 kg) /
320 lbs (145 kg)
