Client has come in with this poster which is approx 2350 x 1110 mm.
Would like it framed to hang on the wall.
Any thoughts?
Very VERY VERY!!!! large poster.
Jon_Brooke
- Interests: Running
Re: Very VERY VERY!!!! large poster.
Having worked on items larger than that in the past, it is a matter of taking baby bites with how you think.
It is definitely a several person crew job.
One is handling and the moving of it in your shop, transport and installation. Measure all areas more that once and run all steps through your mind several times. Thinks of caution to consider are entrances and obstacles in a building that might hinder it moving through hallways etc.
Other that that it is just like any other frame job. Mind over matter.
Any thoughts? Good luck?
You don't mention value. If acceptable to the customer it could be mounted to board through a large roller mounter at a signage shop (and laminated if required).
Timh
Have you asked the customer how he or she intends to collect it
I've had that issue before
Next things is " can you deliver it"?
