Wizard issu
Timh
Wizard issu
Post by Timh »
Hi all
I've got an issue with a Wizard 9000
It has started cutting out mid cut on the final outer edge cut
Pressure seems fine and I have tried increasing it slightly
Any ideas would be greatly appreciated
Kwik Picture Framing
Interests: Picture framing
Re: Wizard issu
fauly cable from the CPU to head. wear and tear. I had to change mine, now okay.
Timh
Re: Wizard issu
Post by Timh »
Thanks for replying.much appreciated
We'll give it a go
TheArtvaults
Re: Wizard issu
Post by TheArtvaults »
Tim , let me know any help you need. Check your large grey cable from Ecu to gantry. Wires on the older gen pull out and contact is sketchy. Give me a call few other things to try cheers Ross
Timh
Re: Wizard issu
Post by Timh »
Cheers Ross thanks for the offer
All the best
