Underpinner - Morso UP-M Manual/Hydraulic
Fellows Framing
Organisation: Fellows Framing
Interests: Framing, Riding
Post by Fellows Framing »
FOR SALE:
Morso UP-M Manual/Hydraulic Underpinner OPEN TO OFFERS
Old but in full working order. Its was my spare underpinner so little used by me. Needs a bit of a clean up and a new home.
"The Morso UPM Under Pinner is an entry level bench model for frame making and assembly. No Power is required - it is operated by a single press on a hydraulic foot pedal. The Up-M is perfect for the small picture frame shop, which does not have a lot of space. The MORSO Up-M can be placed almost everywhere, and does not require any kind of compressor or electricity."
Comes with:
Two stops for wedge position.
Single pressure pad for plain mouldings.
One double pressure pad for mouldings with different profiles.
Adjustable fences - 90, 60 and 30 degrees for rectangular, hexagonal and octagonal frames.
One refillable solid-steel cartridges for 7mm wedge
Part box of 7mm wedges (6000 pcs)
Wedges, cartridges/chutes & spare parts available on line.
Fellows Framing
Re: Underpinner - Morso UP-M Manual/Hydraulic
SOLD
