Honeymonster
Interests: Sleep!
Post by Honeymonster »
Keencut Ultimat Futura 1200 Mount Cutter 48
£1,300 (inc VAT) including postage (UK only)
Still being used until 24th October (may be available earlier), will be dispatched on or abouts 30th October 2024
Call Nick on 07739 212 722.
Ample free parking
Keencut Ultimat Futura 1200 Mount Cutter in good condition. Comes complete with margin guide and squaring arms.
Cuts ultra-high accurate mounts quickly on mountboard of every type and thickness. The cutting head glides on unique built-in self-aligning ball bearing rollers to deliver a smooth cutting action that is precise and produces no friction under load.
Easy cutting of mountboard up to 3.5mm and foamboard up to 5mm. Keencut Futura cuts bevels at 52.5°
Supplied with with 2 partly used boxes of Keencut blades for use with this mountcutter. 15 Keencut Tech D (double sided) 0.012” and 80 Keencut S (single sided) 0.015 blades. The “S” blades are suitable for cutting thicker mountboard.
Supplied boxed, approx. box outer dimensions 149 cm length, 44cm wide
Honeymonster
Interests: Sleep!
Apologies everyone, the correct Postcode is BR5 2HP
Nick (Inspirations Framing)
Townsend
Post by Townsend »
I'm very interested in your Keencut Futura..... If delivery to Northern Ireland is included.
R.
Honeymonster
Interests: Sleep!
Yes, postage is included.
As per my advert, this is still being used and can be posted after 24th October, maybe a little earlier if we get through all the work.
Nick
Honeymonster
Interests: Sleep!
THIS ITEM HAS NOW BEEN SOLD
