POSTER COCKLES
DEEPJOY
POSTER COCKLES
Post by DEEPJOY »
Hi Everyone
Ideas please on how to remove cockles out of posters. They have been exposed to moisture so have a few waves in them (excuse the pun).
I have used a hot press on them , under heat and pressure. It did a kind of a job but not fully. :head:
Re: POSTER COCKLES
Post by JFeig »
Once in a dry mount press the art has to be allowed to dry under weights for a day or more to allow the paper fibers to relax and stabilize.
Re: POSTER COCKLES
I have had some success in the hotpress, putting the work between two sheets of mountboard with only normal 92 heat for 10 mins then pressure for 5 mins.
DEEPJOY
Re: POSTER COCKLES
Post by DEEPJOY »
Justintime wrote: Mon 28 Oct, 2024 1:01 pm I have had some success in the hotpress, putting the work between two sheets of mountboard with only normal 92 heat for 10 mins then pressure for 5 mins.
I ve done 80 degrees was nervous to go go higher and vacuum for 3.5 minutes and them under wieght on a cool flat surface over night. Lets see how they come out.
Re: POSTER COCKLES
Be wary of pressing. There are waves and there are bumps. A wave will probably flatten successfully but a
bump has nowhere to go so can form a tight half-moon crease which is impossible to remove. :|
The key is to not press anything you can't replace and make the customer aware of the risks. :wink:
