Does anyone use CorelDRAW in their processes of mount design - is the Standard 2024 product sufficient or the fuller Graphics suite software.
Which CorelDRAW
Trinity
Which CorelDRAW
- Tudor Rose
Re: Which CorelDRAW
In case anyone saw it/read it and wondered where it had gone: A post on this topic has been deleted by Moderators at the author’s request.
Fruitini
Re: Which CorelDRAW
Standard should be fine. Power trace is a tool I use all the time to generate vectors from images and is available in the standard version. Also the ability to export in .plt format is important for vstudio (Valiani).
JoeB
- Organisation: Niche Frames Europe Ltd
- Interests: Framing, Giclee
Re: Which CorelDRAW
Just so you know, you can use Inksccape and it is free, bit more trouble to upload but the line colours are all that is important, you save as .SVG.
Trinity
Re: Which CorelDRAW
thanks for the responses, I've missed Black Friday but will follow through
- Steve Goodall
Re: Which CorelDRAW
you might be better following "up" - rather than following "through" - I'll get my coat...
Trinity
Re: Which CorelDRAW
Perfectly acceptable 1/2 a century ago
