[img] Framing equipment for sale
Due to retirement
Wizard 8500e mount cutter loads of blades comes with debossing kit ( 3 sizes)
Comes with 45 and 90 degree cutters and blades
Minimum use currently wall mounted but has legs to make into table version.
Comes with desktop pc and silent compressor. £6500 ono
Morso EH version excellent condition has right and left support this is the electric version really good to use saves you knees £5500 ono
Buy both for £10000 and comes with Underpinner and moulding and anything else i have for FREE
Charnwood Underpinner this is really spares and repairs many years old i have used it for years and works for me but has air leaks and is falling apart. Comes with a compressor and lots of wedges.
lots of moulding
Some 2mm float glass
Some mountboard
Any questions
Carl 07760235430
Wizard 8500e and Morso.EH for sale
- Organisation: Old fort framing
- Interests: Framing book binding
- Organisation: james frederick
- Interests: framing,woodwork
Re: Wizard 8500e and Morso.EH for sale
Hi Where are you based please?
Hi i am between halifax and Bradford in Yorkshire
Morso EH
Morso Model EH mitring machine is a fully automatic electric/hydraulic mitring machine, with a noise level below 70db - the perfect machine to cut picture mouldings in production - wooden, plastic and MDF mouldings.
In principle Morso EH does the same work as the Morso F, but with the Morso EH you have your work done automatically by pushing two push buttons. The Morso EH is safe to operate as you must activate both buttons at the same time to have the machine work, and therefore you can't get your fingers underneath the knives. With the Morso EH you can work all day long.
If you compare the Morso EH to a double mitre saw, you will find that first of all the cut with a saw is not as clean and accurate as with the Morso EH. Secondly, there will very often be a problem with the dust from the saw. On Morso EH there is no dust, as the waste of the moulding is lead straight to the ground, which means there's no need for a dust extractor.
If you compare the time spent per cut, the Morso EH normally uses 1 to 1.5 second to finish the moulding. With the saw, it is about the same, so there's no advantage with the double mitre saw...
The Morso EH is supplied with the same standard equipment as the Morso F, plus:
* Extension table to the left side
* Automatic rebate support and moulding clamps
* Measuring scale 1,500 mm with two adjustable stops - you can cut the short and long length of a frame without having to re-adjust the measurements
* Automatic cutting cycles for both large and small mouldings - which means that the machine always does the trim cut.
* Adjustable length of stroke ( 3 positions ) - when using the lowest cutting position the cutting cycle of two cuts only takes between 1 and 1.5 seconds
Comes with brand new spare hydraulic holders
£5500 ONO
£5500 ONO
Re: Morso EH
Oldfort wrote: Wed 22 Jan, 2025 8:08 pm Morso Model EH mitring machine is a fully automatic electric/hydraulic mitring machine, with a noise level below 70db - the perfect machine to cut picture mouldings in production - wooden, plastic and MDF mouldings.
£5500 ONO
Morso SOLD
Wizard SOLD
