Supply chain issue for linen mountboards
ArtistMakesFrames
Organisation: JR frames
Interests: All things art and framing
Post by ArtistMakesFrames »
Hi all,
I have just become aware of a current supply chain issue for linen mountboards with no stock available from Wessex or LJ (I am UK based). Not great as I have been upselling linen boards this month and have about 5 orders for LJ's Gingersnap board!
Does anyone have any experience with making their own linen wrapped boards? Is it worth trying?
AMF
Re: Supply chain issue for linen mountboards
Post by JKX »
If you’ve ever peeled the surface off these fabric boards you’ll know it’s extremely flimsy stuff. If you covered a board with normal fabrics and cut an aperture through that, the corners may not be too clever.
Fabric wrapping already cut mounts is different - nobody does it in UK but it’s a big thing across the pond. I made a trip to the US in 2006 to take a course on it by Baer Charlton, who at the time was a rep for a company called Frank’s fabrics.
He has a range of YouTube videos on the subject, here’s one, you should see the rest.
Tudor Rose
Organisation: The Framing Lot
Post by Tudor Rose »
JKX wrote: Mon 24 Feb, 2025 11:47 am **nobody does it in UK but it’s a big thing across the pond.
..... ** more accurate to say "not many people choose to do this in the UK" maybe?
Our biggest problem is not having a supplier like Frank's Fabrics in the UK where we can reliably get fabric in the same way you can order mountboard. Nothing to stop you getting a supply and creating your own line though, as frustrating as that is compared to just being able to use an existing board.
Wessex have stock of the Crescent cream - you could always get that as an alternative and paint it. Just lift the glass off the surface in case it wants to create wet patches.
We use a mix of LJ and Crescent linens - looks like the LJ ones are being pulled and some of the Crescent ones too. So we might have to resort to creating our own as well - we've not done linen covered before but we've done other fabrics as one offs. Wrapped after cutting the aperture, rather than stuck and then cut. Although we did do a very nice fine oak veneer stuck to a mountboard and that cut really well on our Gunnar.
Post by JKX »
Tudor Rose wrote: Mon 24 Feb, 2025 1:38 pm ..... ** more accurate to say "not many people choose to do this in the UK" maybe?
I probably should have put "Nobody" in inverted commas.
Have a nice day.
Post by vintage frames »
Back on topic,
Pure and Applied Conservation Framing do linen wrapped mounts.
https://www.pureandapplied.co.uk/
