Question about Gunnar F1
woodman-46
Organisation: James Frederck
Interests: Woodwork
Post by woodman-46 »
I have a Gunnar F1 Hybrid mountcutter. Sometimes when cutting a nest of mounts one window of one mount might not quite cut through. Is there a way of selecting that one mount from the nest and cutting it again at a slightly deeper blade setting ?
James
Re: Question about Gunnar F1
I haven't come across that as an option. I usually fix it with a scalpel.
woodman-46
Interests: Woodwork
Yes that sometimes works. It is possible to select a single mount amongst the nest but seems no option to cut that one mount. I tried and it just wants to cut all of the mounts/windows in the nest.
Claim to Frame
Organisation: N/a
Interests: Framing
Post by Claim to Frame »
When I have this, I make sure all the other mounts are cut and removed from the cutting bed. Then delete all the other mounts on the nest leaving just the one you want to recut.
If you need the nest back afterwards, undo brings them back, usually in the same position. Although sometimes it has a funny 5 and no where they were originally.
woodman-46
Interests: Woodwork
Perfect advise . Helped a lot .Thanks.
Claim to Frame
Organisation: N/a
Interests: Framing
No problem at all, after a few years you soon learn the idiosyncrasies of the machine and software :lol:
