Attachments?
- StevenG
Attachments?
Hi, I have a little basic sheet material calculator that I've created to help determine how many sheets of board to use for multiple mounts etc. I was going to share it with the forum but I can't seem to be able to attach anything except for images. Is this right?
Re: Attachments?
Testing
- StevenG
Re: Attachments?
OK, I've changed the extension to .pdf and attached the file. Obviously this isn't the right thing to do but at least it'll be attached to this post. If anyone wants to test or do whatever the file extension will need to changed to .html. It's written in HTML as I thought it would leave it less device/platform dependent. It doesn't use any fancy external libraries or any non standard background 'engines' so it should be working in any up to date browser.
It's nothing fancy but it should help the user get a better idea of what's needed in terms of materials.
UPDATE: The attachment failed again due to "The upload was rejected because the uploaded file was identified as a possible attack vector."
