Carbon Fiber style moulding
Parm
Organisation: Studios
Interests: Classic car restoration
Post by Parm »
Hi All, A customer who is also a F1 fan wants a few A3 posters framed for his man cave. Ideally he wants a flat profile no wider than 25mm the style of the moulding to resemble black carbon fibre… Any help sourcing such a moulding (if it exists!) greatly appreciated. Thanks in advance!
Re: Carbon Fiber style moulding
Post by JKX »
I’m not aware of one but you could easily make your own, Google “carbon fibre wrap”.
Then a metallic grey mount and a deep bevel wrapped in the same stuff would look the biz!
Post by vintage frames »
Exactly..
You can buy self adhesive 25mm wide carbon fibre tape and stick it down onto some flat moulding.
https://www.amazon.co.uk/Spurtar-Air-Re ... 53f209f
Parm
Post by Parm »
Thank you . Ill give the wrap a try
David
Post by David »
I've been wrapping ‘carbon’ frames for a long time. Get a vinyl that is intended for external use on cars, it’s generally guaranteed for 5 years. I have pieces I did over 10 years ago and they still look new. There are different finishes, I go for a matt 3D textured pattern. A tip when cutting the vinyl cut the short sides at 90 degrees to the long sides so the weave pattern is in the same direction. I also wrap each length before joining, folding the vinyl over the end of the moulding, this gives a cleaner more stable join. This does mean a weaker frame joint so I brace it with a 90 degree metal corner plate. If you want a really thin frame you can use an aluminium frame which takes the wrap well, otherwise anything with a smooth finish.
David
Post by David »
This shows the 4 lengths wrapped before joining. This one is a grey 'carbon'. It also shows the different directions of the weave pattern.
David
Post by David »
And a joined corner.
Parm
Post by Parm »
Gosh David, that’s super helpful, saved me a lot of trial & error. Thank you!
BaBaZa
Organisation: http://www.mainlinemouldings.com
Interests: Pubs
Post by BaBaZa »
Twitter #MainlinePolcore
Parm
Post by Parm »
Great, can you send a chevron sample?
BaBaZa
Interests: Pubs
Post by BaBaZa »
Parm wrote: Fri 10 Apr, 2026 6:57 pm Great, can you send a chevron sample?
Certainly, please send and email to the sales team or complete the contact form: https://mainlinemouldings.com/contact-us/
