Aluminium frame assembly - what am I doing wrong?
WannabeFramer
Organisation: Arlais Framing
Post by WannabeFramer »
I am assembling a small aluminium frame and can't work out where I am going wrong. It has perfect mitres when fitted without the brackets, but then each time I tighten the screws, the frame goes out of square. I can see and feel it moving out of square as I tighten the screws. I have tried holding it tightly, clamping it, bracing against a square. Each time the same. I am quite literally :head:
I took a video to show what happens but I can't upload it.
What really, really obvious thing am I missing?
theframer
Interests: football,fishing
Re: Aluminium frame assembly - what am I doing wrong?
Post by theframer »
does it have the double plate hardware?
Are you using the 2nd plate if so?
Will it not tap back around when tightened up back into place.
WannabeFramer
I am using the fixing kit that came with it, one bracket for each corner. No, it will not tap back into place. If I slacken the screw off even a tiny bit I can wiggle it back, but it is then not secure.
This is with the brackets in loose:
Then tightened:
Have you tried flipping the bracket over to see if it makes a difference?
WannabeFramer
You sir are a genius. Yes!! I was using the screws as they came in the brackets. Took them out, put in the other way and result! :clap:
This reverse way has Face stamped. Not sure which way it should be, but it worked.
:bow:
