Dry mounting
Thewhitewallgallery
Organisation: The White Wall Framers
Interests: Sports and Framing
Dry mounting
Post by Thewhitewallgallery »
Our supplier has changed the usual adhesive boards we use to dry mount and we are having nothing but problems with air bubbles etc.
Looking for any advice or suggestions for adhesive boards to maybe help combat the problem or even what machine would be best to purchase as we do quite a lot of large photos.
Any help is appreciated. Thanks in advance.
Matt
Re: Dry mounting
Sticky boards where the photo is set with a hand roller are prone to bubbling, in fact it's almost a
certainty. The bond is pressure sensitive and you need a roller press to even stand a chance.
You just can't get enough even pressure down by using a hand roller.
A heat press is more expensive and takes up a lot of space but it will do a more permanent and reliable job. :clap:
Re: Dry mounting
I love the Hotpress but you are limited by the size of it's bed. If space was no issue I'd get a full size Drytac Jetmounter. Size is unlikely to be an issue with that.
Thewhitewallgallery
Re: Dry mounting
prospero wrote: Thu 08 Jan, 2026 3:03 pm Sticky boards where the photo is set with a hand roller are prone to bubbling, in fact it's almost a
This was what I thought may be the case. Looks like a heat press it is. Thanks for the reply
Thewhitewallgallery
Re: Dry mounting
Justintime wrote: Thu 08 Jan, 2026 4:20 pm I love the Hotpress but you are limited by the size of it's bed. If space was no issue I'd get a full size Drytac Jetmounter. Size is unlikely to be an issue with that.
Are they simple to use?
Thanks Matt
Tudor Rose
Organisation: The Framing Lot
Re: Dry mounting
Post by Tudor Rose »
Yes, very easy to use.
We had both Hotpress and Jetmounter. Now sold the Hotpress as we just very rarely used it. The Jetmounter gets used regularly and we wouldn’t be without it.
Thewhitewallgallery
Re: Dry mounting
Tudor Rose wrote: Fri 09 Jan, 2026 8:33 am Yes, very easy to use.
Thank you for the advice. Going to try the Jetmounter first.
Richard Photofusion
Organisation: Photofusion
*young, now a teenager...
Re: Dry mounting
Post by Richard Photofusion »
We had an HGP360, and quickly switched to a JM44 jet mounter. I can flood coat a case of 1000x1400 kapamount in around an hour, including trimming excess and repackaging.
The larger machines have a take up reel, which is very useful for laminating, as you can run cleanly, in a pseudo roll to roll set up.
Steve Goodall
Re: Dry mounting
Post by Steve Goodall »
The cold weather doesn't help with self adhesive boards either.
