Brevetti Mitre Saw Dust Extraction
Louiss
Organisation: Louiss
Interests: Framing, woodwork and art.
Post by Louiss »
Hi all,
Hoping for some advice from anyone using a Brevetti mitre saw. Has anyone managed decent dust (and offcut) collection on these? Do you just stick a box inside, or is there a better solution?
We’ve got a Prismatic E, and I used the manual Prisma a decade ago which was the same.
I’ve tried hooking it up to a dual motor Record Power CamVac. It stops dust escaping, but most of it just settles in the bottom of the saw rather than making it to the extractor. The saw body is basically a big empty box, so maybe it's not possible without a enormously powerful extractor?
Bit frustrating having to keep opening it up to clear out offcuts and piles of dust.
Cheers!
Louis
Re: Brevetti Mitre Saw Dust Extraction
Post by vintage frames »
I'm afraid the Canvac isn't going to do it for you.
What you need is a decent dust/chip extractor.
Something like one of these -
https://www.scheppach.co.uk/en-GB/Dust- ... EALw_wcB
Go on Facebook marketplace and you should be able to find one for £100 or less.
When you do get one, stick it in the loo or somewhere self contained. That way the residual dust won't bother you.
Louiss
Post by Louiss »
vintage frames wrote: Thu 16 Apr, 2026 2:53 pm I'm afraid the Canvac isn't going to do it for you.
Thanks, I was afraid that was going to be the answer. We do have a spare one, but I was hoping to avoid using it for this. Ho hum.
Thank you though.
One one I showed was for illustration only.
Look for one with at least a 1hp motor, that way everything gets sucked out.
Fruitini
Organisation: Original Glory
Post by Fruitini »
We've got a 2hp 1500W Charnwood extractor attached to our Prisma and even this doesn't directly remove all sawdust. Does a great job of keeping the dust away from the action area however most remains in the base of the machine which needs to be dealt with when too many triangles build up. Not the most fun job in the workshop admittedly! Just turn the extractor on and toss handfuls of dust towards the vents! Doesn't take too long. Dermot's advice about locating the extractor in a contained space elsewhere is a valid one - residual dust from the extractor is problematic.
