Gunnar F1 Hybrid question
Tony Owen
Organisation: Auckland Council
Interests: Bookbinder
Post by Tony Owen »
Hello,
I have to install a Nylon foot pad for the first time , I notice that the old pad due to wear is considerably thinner than new pad.
I assume that install a thicker new pad will affect the deboss/ cutting depth, what adjustment should I make to ensure correct deboss cutting depth with new pad installed?
I had a look online for "how to" videos for could not find anything specific to resolve this.
Any advice most welcome
Thank you
Tony Owen
Re: Gunnar F1 Hybrid question
Sarah at Gunnar UK would be able to help you with that question. In the meantime I'd do a test cut to see if the change actually does make a difference to the cutting depth. If in doubt then go through the recalibrating the blade depth routine which is available in the help/configuration section.
Sarah can be contacted at 07976 378704.
Tony Owen
Post by Tony Owen »
Thank you much appreciated
