Acrylic for frames
Posted: Tue 01 Sep, 2026 3:59 pm
by Parm
Hi all. May I pick your brains! I don’t use acrylic - only real glass, however a regular customer has asked for two frames with acrylic in. Sizes are 25.9x19.7 & 21.4x20.7cm
Q1: Would 2mm be ok or should I buy 3mm thickness ?
Q2: suggestions on how to cut down a large sheet please? Straight edge and sharp blade?
Thanks in advance!
Re: Acrylic for frames
Posted: Tue 01 Sep, 2026 9:33 pm
by Justintime
2mm is absolutely fine for those sizes! You can order cut to size from Wessex. I have used a wall mounted panel cutter with acrylic blade, but I'll guess repeated strokes with a Stanley knife would work too if you have strong arms. Just don't scratch it.
Posted: Sat 12 Sep, 2026 12:05 pm
by Parm
Thank you!
Posted: Sat 12 Sep, 2026 4:49 pm
by pramsay13
2mm is fine at that size. You can order cut to size from most suppliers or cut your own.
A hooked blade is good for this and use repeated strokes and then snap over the edge of the table.
