Main features
1. Pneumatic operation
- Uses compressed air to operate the cutting mechanism.
- Pneumatic clamps hold the mountboard securely in position.
- Consistent blade pressure and cutting depth help produce clean, accurate bevels.
- Requires an air compressor operating at approximately 6 bar (90 PSI).
2. 45-degree bevel cutting
- Produces accurate, professional-quality bevelled apertures.
- Suitable for single and multiple aperture mounts.
- Can cut double and triple mounts without removing the board from the machine.
3. V-groove cutting
- Produces decorative V-grooves directly into mountboard.
4. Pneumatic clamping system.
This eliminates the need to repeatedly turn the mountboard, improving speed, accuracy and productivity.
Technical specifications
Maximum working area 1200 × 800 mm
Overall height 1800 mm
Overall width 1570 mm
Overall depth 600 mm
Approximate weight 100 kg
Air requirement 6 bar / 90 PSI (compressor not included)
I have used this machine for the past 5 years. Not included is a compressor, but does include the mountboard end trimmer and spare cutting blades which are readily available.
£450.00 ono - no VAT.
2. Keencut 4000 wall mounted glass and board cutter
- Mountboard cutting: Cuts mountboard, matboard and foamboard using a utility blade.
- Glass cutting: Dedicated glass-cutting wheel for scoring picture-frame glass. (Includes 18 new Bohle glass cutting wheels)
- Acrylic cutting: Scoring facility for acrylic and other rigid plastics.
- Hardboard cutting: Twin rotary cutting wheels for hardboard, Masonite and heavy-duty card.
- Vertical operation: Materials are supported vertically, helping with handling and positioning.
- Measuring system: Incorporates measuring scales and a squaring arm for accurate cutting.
- Multiple cutting heads: Separate carriers provide different cutting functions.
I have been using this for the last 5 years and replaced with a Keencut Excalibur to cut larger glass and hardboard.
£250.00 ono - no VAT.
Reply or call Greg at FrameLogic on 07802 740363
www.framelogicpro.com
