Vacuum removal of Morso waste.
Posted: Sun 06 Jul, 2008 6:00 pm
I've just invested in a Earlex Combivac from Argos. It's a wet or dry workshop vacuum cleaner and for those who are interested, the price was £39.99, the catalogue number is 710-2279 and it even claims to be suitable for clearing rubble and broken glass.
The principle intention in buying this was to suck out the waste wood chips from behind the Morso. Having just tried it, I can report that it does the job. From time to time some larger chips will not fit into the hose diameter and there is a bit of a nack to using it without sucking too much into the end of the hose and choking up the nozzle.
I would not particularly recommend it as a better method of removing the Morso waste, as I think the Morso waste chute and a suitable collecting box probably beat everything else, if you've got space for it. Unfortunely my very small workshop means my Morso is against a wall and this is now my prefered and "easier" method of removing the waste chips.
If all else fails, this may be a practical solution for others.
